Muse AI for actual work: finding decisions in meeting recordings
I tried using Muse AI to find a decision in a meeting recording and still ended up scrubbing through it manually. The file was a screen recording of a project handoff, and I needed the point where we settled on who would update the checklist.
Is anyone using Muse AI for actual work like this, with practical examples of what reliably saves time? I’m trying to make this part of my handoff routine, not add another review step.
Capture the decision while you’re making it. For future handoffs, I’d end with a spoken recap: “Checklist owner is Alex, update due Thursday,” and put that same line in the handoff note. That gives you a specific phrase to look for in Muse AI if you need the surrounding discussion, without making the recording your only record of ownership. It won’t rescue this recording, but I’d aim to use video search for checking context, not reconstructing assignments after every meeting.
Don’t assume the assignment was actually said out loud. In a screen-share handoff, “yep, that works” could be the whole agreement while someone changes an owner cell onscreen. @jeff’s recap would prevent that ambiguity, but for this recording I’d search for the task name rather than the person, then watch the shared document around those hits. You may be hunting for a visual edit, not a searchable sentence.
I’d expect Muse AI to narrow the hunt enough that I’m reviewing a few short stretches, rather than replaying the handoff. Some manual checking is reasonable. Having to scrub through the whole thing anyway would leave me questioning what the search actually saved.
The catch is that finding an assignment and finding the final assignment are different jobs. Someone could volunteer early, then hand it off later because they don’t have access or will be out that week. A search result containing the task and a person’s name could look convincing while pointing to an arrangement that didn’t stick.
That’s my caveat to @emma1996’s suggestion: an owner change onscreen is worth investigating, but I wouldn’t stop there. For this recording, I’d work backward through the relevant matches. Treat the last discussion of that task as a candidate, listen through the transition to the next topic, and check whether they actually settled it or left it pending. Then use earlier matches to fill in whatever is unclear. That seems less wasteful than starting with the first mention and following every proposal forward.
I’d keep the wording of any resulting note honest, too. “Proposed owner” and “confirmed owner” shouldn’t become interchangeable just because you found a timestamp. If the clip ends with someone saying they’ll check with another teammate, you’ve found an unresolved assignment, not a failed search.
If ownership is needed to get work moving, I’d put a limit on the archaeology and ask the people involved to confirm. That won’t establish exactly what happened in the meeting, but it can settle what happens next. I’m skeptical of treating recording search as a decision record unless it makes the supporting context easy to check. A plausible hit alone isn’t enough.
If you have the timestamp that you found manually, use that passage to test the search before wasting your time trying different queries. Listen for a unique word that is likely to appear near the assignment, and search for it. Pick something clearly stated, rather than a name that could be misspelled. Now you have a passage that you know is there, to test against, instead of trying to guess whether the answer is anywhere in the recording.
That’s where I’d pause @smartpulse’s backward-search approach. It depends on the relevant stretches appearing in the results at all. If search can’t bring back a passage you know contains your chosen word, reviewing the matches in a different order won’t address that miss. I wouldn’t call that proof the whole tool is broken, but I wouldn’t trust an empty result to mean the task wasn’t discussed, either.
If that word were to be found, try the wording that you have searched as to find the decision. That comparison is a better complaint than ‘I still had to scrub’: searching could locate the actual wording, but your description of what you needed didn’t lead there. Those are different problems, even though both wasted your time.
For real work, I would want that little check before going in to a search routine. Otherwise you can spend more time fine-tuning the queries than reviewing the video, with no way to tell if the way you were phrasing was at fault. Keep the timestamp and the failed query together if you give feedback. That gives support a real miss to investigate.
The decision moment in a screen-share is often the least searchable part of the whole recording. Watch how people actually talk when they’re staring at a shared doc. It turns into ‘yeah that one,’ ‘move it up,’ ‘okay cool, next.’ No task name, no owner name, just pronouns pointing at pixels. So the thing you want to search for was never spoken. That’s not the tool failing to find your words, it’s that your words aren’t in the audio at all.
Which is why @m3g4_shell’s test idea is smart but might give you a false negative. You pick a unique word near the assignment, search it, it comes back, great. But that proves the transcript is searchable, not that the deciding sentence exists as text. The pointing-and-grunting stretch can transcribe as noise while everything around it indexes fine.
@emma1996 had the right instinct going for the visual edit instead of the sentence. I’d lean harder into that. Muse AI is reading the audio track, not the pixels of the spreadsheet, so an owner cell changing onscreen is invisible to search no matter how you phrase the query. If the real evidence is a cell that changed, no search routine reaches it. You scrub to it or you don’t find it.
My honest expectation for this specific recording: search gets you into the neighborhood of the task discussion and then you watch. That’s fine. Where I’d stop trusting it is treating a clean hit as the decision. @smartpulse’s point about proposed versus confirmed is the one I’d tape to the monitor. A transcript line with a name in it tells you the task came up, nothing more.
Going forward I wouldn’t fix this with better spoken recaps alone. Timestamp the decision in the handoff note itself. One line, task plus owner plus the exact clock time in the recording. Then the recording becomes a thing you jump to, not a thing you search, and the ambiguity never gets a chance to start.
Whether or not you have access to the document shown in the handoff is important here. If it has version history, I would look at this before searching through videos. You have an alternate source of information to look into, and it may not be hard to see the difference between versions of the document. The task may have been assigned to someone else, a comment could’ve been added to clarify something, or maybe the task was renamed for easier searching.
Look at the surrounding versions around the meeting and the task’s row. See if you can find a changed owner field, a comment saying who owns it, or maybe the task was renamed. If you see a timestamp for an edit that’s relevant, you can look at the video around that area. Don’t look for the exact second, leave a little bit of space around that area.
That’s where I’d push back on @cyberhive2855lab’s “you scrub to it or you don’t find it.” Even if video search misses the onscreen evidence, the underlying document might preserve it. There’s a catch: the person who edited the field isn’t necessarily the person assigned the work. And today’s document won’t necessarily show what was agreed during that handoff, so check the historical version rather than just opening the current sheet.
This would not indicate that Muse AI did its job well. It separates asking for the answer from investigating the search. As for the immediate task, I would follow the records that give you a shorter, checkable segment to review rather than asking that all the way back to the choice point be laid out in detail.
Edit timestamps in version history lie more often than people expect. @hyperpilot3378 is right that the document often holds the evidence the audio doesn’t, but the clock on a changed cell is not the clock on the decision. Autosave batches things, offline edits sync late, and someone can tidy a sheet an hour after the call ends. So if you jump to the video based on an edit time, leave yourself a wide window, because the edit might have happened while nobody was even talking about that task.
The thing nobody’s chased yet: the decision usually leaves a trail after the meeting, not just inside it. A handoff that actually settled ownership tends to produce something downstream. A task gets created or reassigned in whatever tracker you use. A message goes out saying ‘Alex has the checklist.’ A calendar hold appears for the Thursday update. Those artifacts are quick to check and they answer the question @smartpulse keeps circling, proposed versus confirmed, better than any clip can. If Alex opened the task and started working it the next morning, that’s a stronger signal than a transcript line where someone muttered a name.
Which is why I’d flip the order of work here. Before scrubbing or searching, look at what moved in the hours and days right after the meeting. If the owner is obvious from that, you’re done and you never touch the recording. If it’s contradictory or empty, then you’ve got a real reason to go dig into the handoff, and now you know roughly what you’re looking for.
Muse AI is fine for landing you near the discussion, no argument there. I just wouldn’t ask it to tell you what stuck. It reads what was said, and what was said is frequently the weakest part of the whole record. The strongest part is what people did afterward. Chase that first and the archaeology gets a lot shorter.
