The laptop choice begins with your software stack, not the model size. A machine can have enough memory to load your model and be a bad development box because halfway your dependencies expect CUDA, a package does not have an ARM build, Or an acceleration backend supports inference but not the operation you need.
For the broadest compatibility, I would compare the options like this:
Windows with NVIDIA and WSL is usually the safest single-machine choice when repositories assume CUDA or Linux tooling. You get access to mainstream developer software, but you are managing two environments, file paths can be annoying, and Docker plus WSL plus a browser can eat a surprising amount of memory.
A Mac with a large, unified-memory configuration is attractive for quiet coding, battery life, and running quantized models through Metal-friendly tools. It is much less attractive if your work involves CUDA extensions, custom kernels, or projects tested mainly on NVIDIA hardware. “Runs local models well” and “runs my AI development stack without edits” are different things.
A Linux laptop with NVIDIA removes much of the WSL friction and gives you a setup closer to typical remote GPU servers. The compromise shifts to laptop hardware support. Sleep, external displays, battery management, fingerprint readers, and GPU switching can require more patience depending on the model.
I agree with @neonserver411 that remote compute gives much better performance per dollar, but it does not completely replace matching local hardware. If you write and debug against CUDA locally, an NVIDIA laptop can save time even when the serious jobs run elsewhere. If you mostly call model servers, build retrieval pipelines, or test application logic, paying for a large mobile GPU makes far less sense. Your local machine only needs enough resources to keep the editor, containers, database, and browser responsive.
Before buying, take a representative project and install it on the OS you’re planning to use. Check each dependency, including quantization libraries, attention implementations, container support, and custom extensions. This test will narrow the field faster than benchmark charts will. For a general recommendation, I would pick a well-cooled NVIDIA machine for CUDA-heavy experimentation, a high-memory Mac for portable local inference and ordinary application development, or a quiet business laptop plus remote GPU access when the model itself is not the product you are debugging.
