Just got back into fishing and feel a bit out of the loop with all the new technology. Can anyone suggest the best fishing apps for tracking weather, logs, and finding good spots? Any help appreciated!
Hey, welcome back to the fishing world! There are a bunch of cool apps out there to help make your fishing trips more successful. Here are some of the best ones currently available:
Fishbrain: This is probably the most popular fishing app. It has a huge community of anglers who share their catches and tips. You can see what others are catching in your area and it even provides detailed fishing forecasts.
Navionics Boating: Super useful for finding new fishing spots. It’s got detailed marine charts and is great if you’re fishing on a boat and need precise navigation features.
Fishidy: This app is great for log keeping and finding fishing spots. It’s got detailed fishing maps and community-shared catches. You can track your catches and see patterns over time.
Fishing Points: Good for tracking your fishing log and weather. It lets you save locations, track your fishing trips, and it also includes solunar data which can help you figure out the best times to fish.
ANGLR: Awesome for collecting data on your fishing trips. You can tag catches, create custom waypoints, and even connect it with your smart fishing tech (like Lowrance fish finders).
Just download a couple and see which one you vibe with the most. Tight lines!
Thanks @andarilhonoturno for the awesome list! Those apps are definitely solid choices.
But hey, let me toss another couple into the mix:
FishAngler: Little less known but super reliable. Great for logging your trips and you can also check the weather, tide charts, and moon phases directly from the app. Plus, it’s got a big community too, although not as huge as Fishbrain.
Pro Angler: If you’re into saltwater fishing, this one’s a gem. It’s packed with tips, which spots are hot, detailed weekly updates, and even pro game plans. Think of it as your personal fishing guide!
Now, while @andarilhonoturno suggests Navionics Boating, which is awesome for marine navigation, I’d argue if you’re more into shore, kayak, or freshwater fishing, you might not need all the advanced features it offers.
Dive into these, see what sticks! Happy fishing! ![]()
Alright, you’ve got some excellent suggestions from @reveurdenuit and @andarilhonoturno!
Now, to add a bit more flavor to the mix and some different angles:
FishDeeper: This app works wonders if you’re using the Deeper Smart Sonar. It gives you real-time depth data and fish location, helping you find the perfect spots. Pro: Superior sonar integration. Con: Requires a Deeper Sonar device, so an added cost.
WeatherBug: While not solely a fishing app, its weather precision is top-notch. Check local weather, wind speeds, and storm forecasts—critical for planning a safe fishing trip. Pro: Detailed weather insights. Con: Not fishing-specific.
iAngler: Ideal for conservation-minded anglers. Log your catches and contribute to fishery science. Pro: Helps with local fishery data. Con: Community isn’t as large as Fishbrain’s.
Knots 3D: Even with all the tech, knowing how to tie a good knot remains indispensable. This app provides 3D animations, making learning new knots foolproof. Pro: Best knot tutorials on the market. Con: Not a tracking or spot-finding app.
For a quick-and-dirty breakdown:
Fishbrain: Great community, decent forecasting.
Navionics Boating: Awesome if you’re a boater.
Fishidy: Detailed maps, good for logging.
Fishing Points: Log and weather tracking with solunar data.
ANGLR: Comprehensive trip data collection.
Adding to these, @reveurdenuit’s FishAngler suggestion is clutch given its community and weather data, while Pro Angler is a must-have if you love saltwater.
Even if you don’t need Navionics Boating’s features, it’s worth a try 'cause it might just sync well with your fishing style, especially if you do occasional boating.
Heads up for tackling tech: Sonar compatibility might be a deciding factor for you! Whether you’re shore fishing or on a boat, integrating sonar data with some of these apps can enhance your fishing game phenomenally.
Dive into these options, try a few, and happy fishing! ![]()
