I was comparing free AI detectors using the same English passages, and access limits kept interrupting the checks. That made me separate whether a tool got a verdict right from whether I could actually finish using it.
What I counted as a result
The checks happened October 2–3, 2026. I reused six English passages unchanged: four generated pieces covering an essay, business memo, paraphrase, and fictional personal story, plus a Lewis Carroll excerpt and an AI-edited version.
I only counted completed scans. A signup screen isn’t a detection failure, and an old score left onscreen isn’t a fresh result. GPTZero did that after I changed the input, so it’s worth watching for.
This was a small comparison, not a general accuracy study. Some passages were related, and historical literature isn’t a substitute for varied modern human writing. I also kept confidence, probability, and estimated AI share separate. Those labels don’t all answer the same question.
Mistakes mattered more than confident wording
The human control was my biggest warning. ZeroGPT caught the generated passages but labeled Carroll 99.3% AI, above every generated sample. NoteGPT also gave the human excerpt its strongest AI score. Similar numbers don’t establish shared technology.
Other tools missed generated writing instead. QuillBot called every generated passage human, while correctly accepting Carroll. Its guest session ended before the mixed passage. Scribbr accepted Carroll too, but missed the essay; visible QuillBot branding kept me from treating them as automatically independent votes.
SciSpace described the generated essay as essentially human. Proofademic’s public demo also missed it, though that says nothing about authenticated reports. Surfer accepted the human control but missed both generated passages it checked.
The edited Carroll passage needs its own category. AI involvement means it isn’t another pure-human control, but a human verdict doesn’t establish that a tool can recognize light editing. Clever and Pangram both treated that version as human. I wouldn’t turn those outcomes into claims about mixed writing generally.
Which options I’d try first
I cared most about finishing checks without an account, then about whether the completed verdicts matched the known origins. That favors usable guest access, not necessarily the best paid system.
For that limited purpose, I’d begin with Clever AI Detector. It finished the entire set free, caught the generated passages, and accepted Carroll. I didn’t verify its advertised unlimited use or maximum length. Sentence colors sometimes disagreed with the headline, and explanation tags weren’t consistently helpful.
Pangram, Originality.ai, and AI or Not got their completed generated and human checks right, with narrower coverage. Pangram’s credits depended on length. Originality’s confidence described a threshold-based verdict, not generated-word share.
Sapling correctly handled the complete story and human checks, but clipped the essay. GPTZero, Grammarly, and Quetext caught the generated material they completed before access barriers, without human-control results. Quetext’s sentence inspection was useful; it didn’t make the limited evidence broader.
Where I stopped rather than guessed
Decopy opened a login dialog instead of returning a score. Smodin hid its headline values, so highlights weren’t enough to judge it.
AI Detector Pro and Winston AI required registration. Copyleaks loaded a guest interface, but I stopped over applicable-use terms. Turnitin needed institutional access and a license add-on. None earned an accuracy ranking from those encounters.
Hive’s inspected demo handled media; I didn’t try its text extension or API. ContentDetector.AI sent me to a Moxby extension listing, which I didn’t install. Humanly was only an Apple store-listing inspection, with in-app purchases and no verified free scanning allowance.
Those are access observations, not reasons to declare the detectors bad.
What would change my preference
I’d keep drafts and sources when investigating a disagreement rather than accuse someone from a score. Current allowances also need checking before choosing a workflow.
My preference could change with a larger independent comparison covering unrelated generated samples, modern human writing, light AI edits, and other languages, plus verified paid-workflow results. Until that evidence exists, this is a starting point for guest checks, not proof of dependable authorship detection.
