What are the best AI-based crypto projects right now?
I’m looking to invest in AI-driven cryptocurrencies and want to know which ones are considered the best in 2024. There are a lot of projects out there and it’s hard to tell which are legitimate or have real potential. Any help with recent trends, advice, or personal experiences would be appreciated.
Trying to pick AI-based crypto projects is honestly like playing 4D chess against a gorilla with a rocket launcher. The space is so hyped right now, everyone and their mom’s meme coin claims to have “AI integration” when all they did was slap ChatGPT into their Discord server. That said, a few projects actually seem to have SOME juice:
  1. Fetch.ai (FET): Been around a while, real team, doing autonomous economic agents, AI-powered ML tasks, industrial partnerships. Actually shipped code, not just a bunch of whiteboard doodles.
  2. SingularityNET (AGIX): “Decentralized AI marketplace” is the tagline. It’s part vision, part actual product. Plus, their founder is literally the guy with the white ponytail who built Sophia the robot. Either genius or Bond villain vibes.
  3. Ocean Protocol (OCEAN): Less “AI” and more “data marketplace for AI” but that’s probably smarter, tbh, since actual AI training is mega expensive. Partnerships with big players like Daimler.
  4. Akash Network (AKT): Not 100% “AI” but decentralized compute for AI tools. Think AWS for blockchain AI nerds.
  5. Bittensor (TAO): Wonky but interesting—decentralized neural networks where users and miners contribute to AI models and get rewarded. Pretty niche, but hardcore devs actually like it.
Red flags worth noting: there is SO MUCH vaporware out there. If the “AI-powered” project can’t explain their tech without using every Kraken-level buzzword or if their Github is deader than my enthusiasm for conference calls, run. If team is anonymous = risk squared. Oh yeah, “AI trading bot coin” promises? They turn out zillionaires mostly for the devs, not buyers.
Checked the charts and, surprise, most legit projects have already pumped with this year’s AI crazy run. DYOR, but these are the ones not obviously made by Joe Shmoe in his basement. And don’t bet the farm unless you wanna end up learning to code yourself.
Bold take but I kinda have to side-eye ALL “AI crypto” projects at this point. Not disagreeing with @jeff on some being genuinely technically interesting—Bittensor and Ocean probably have the more defensible logic and dev traction. But honestly? The second a market narrative pops off, these coins go into hyper-meme overdrive, and suddenly everything is “AI-powered” just because someone plugged in an LLM API call.
Let’s also be real: what do most “AI cryptos” actually do for the average investor besides generate speculation? Fetch, Ocean, and AGIX have working stuff, but the token utility is often a stretch (do you NEED to buy their token to make use of anything AI-ish, or are you just holding the bag hoping others will FOMO in?). The AI data marketplaces—cool on paper, but network effects and quality control are brutal hurdles. Bittensor’s “proof of intelligence” model is the most unique, but dang, try reading their docs without getting a headache.
If you want less risk of holding vaporware, check partnerships, code commits, and—big one—community engagement (no, thousands of bots don’t count). For me, I’d focus on projects that empower other devs/companies (like Ocean does) rather than stuff promising “autonomous AI trading bots that never lose.” If it sounds too good to be true, it always is.
Final note: AI blockchains right now are experimental. This scoop is more about betting on the idea of decentralized AI in its wild early days, not a surefire short-term moonshot. Just don’t let a hot subreddit thread trick you into thinking everything with “AI” in it is the Next Big Thing. Most are “crypto first” and “AI” because that’s the flavor of the month. Stack only what you can afford to meme away.
Everyone’s hyped about AI and crypto fusing like Voltron, but honestly, the AI-crypto Venn diagram in 2024 is mostly a big blob of “speculation.” Not throwing shade at previous answers—points about due diligence, code commits, and non-anon teams are legit. But let’s zoom out: most “AI” tokens look like a branding exercise with a few API calls sprinkled on top.
So what actually has value beyond a Twitter pump thread? Fetch.ai (FET) does have real partnerships and deployed networks, but the utility for an average bag-holder rarely extends past speculation. SingularityNET (AGIX) gets creds for OG status and vision, but their “decentralized AI marketplace” still feels mostly aspirational. Ocean Protocol (OCEAN) wins on real-world data utility—actual companies use it—but then you’re betting on data, not cutting-edge AI per se.
For those galaxies seriously thinking about “AI-driven crypto can change everything,” here are some unique (and maybe contrarian) takes:
Pros for ':
  • If you value decentralization + AI, this is one of the few spaces merging both, potentially giving small players access to compute/data marketplaces previously walled off.
  • Some projects (like Bittensor) are doing wild, experimental stuff—if that takes off, early holders could win big.
  • Real dev engagement and open GitHub activity show things aren’t just vapor.
Cons for ':
  • Most tokens are utility theater—actual user demand for the token is low/unclear.
  • If “AI” = “plugged in ChatGPT to a smart contract,” it’s not revolutionary tech.
  • Prone to meme cycles: can dump on retail quickly if hype fades.
TBH, I slightly disagree with how much weight is put on “partnerships.” Crypto is littered with projects claiming partnerships after a single press release or hackathon. Track engaged developer activity and actual usage stats on-chain, not just flashy announcements.
Catch? The AI+crypto overlap is early, possibly years out from real utility. If you want low-key exposure and can stomach volatility, small stacks in the heavy-hitters like OCEAN, FET, and AGIX could maybe pay off, but it’s not a “pick the next Google” moment. The smarter money watches what infrastructure plays (compute/data layers) get adoption rather than yet another “AI bot token.”
Bottom line: invest for the tech, not just the narrative. And if all else fails, remember most of these coins are just a few spicy meme cycles away from irrelevance—so size your bets, then load up on popcorn.
